Steering column plastic sleeves/bushes
5 weeks to get 2 plastic sleeves for my steering column from Westfield anyone know where I can get some from cheers
is it the same as these?
Top steering column bush: Ford Escort Mk2 MP1010
  1. Top steering column bush: Ford Escort Mk2 MP1010
  2. No Tax, Each £3.41 Taxed, Each £4.09
  3. Qty: Add to Cart
  4.
  5. Burton Power
  6.
  1. Part Number: MP1010
    Nylon bush machined to replace original worn bush in Mk2 ste.... Learn More
  2.
  3. Available From Stock
  4.
  5.
I'm sure these are a bespoke westfield part
what is wrong with the ones you have fitted ?
they are easy to make but better if you make an exact fit to your housing and column to get the tightest fit and no play.  10 minutes on the lathe. Happy to make if you are local to Kent postcode tn8
if if you only have a small amount of slack just painting the column where it rubs may be enough to improve
Mine's had a rattle at the top and bottom bush since new :cry:
I put loads of graphite grease in mine and it makes it smoother and no play. You could remove it and use some very thin shimming material to take up the wear by sliding between the column and bush .
Wow thanks for all the help
it's a 2012 model and just put two new universal joints on and wanting to replace these they have just worn that's all but as usual Westfield don't have anything for a Westfield
going to replace them
and thanks but I'm nowhere near Kent based in west yorkshire
thanks guys
could well be the escort ones
look the same anyway
I had the same fiasco a few years back. Told me no stock but pay for them now and we'll post automatically when they come in next week. Week comes and goes so I call them .. "we never ordered them because they're in stock all the time" ??? :angry: Oh, and when they did arrive, they were worse than the originals .. by a long way!!
All that for two nylon collars .. I wish I knew someone that could run them up locally. Landed up re-using my originals packed up with a bit of graphite grease like Trustyjust did.
Mine too...:no:
Mine too and I still married her ...................:laugh:
  • Haha 1
