Geoff101 Posted August 20, 2017 Posted August 20, 2017 Standard fuel tank for narrow body with independent suspension. Top filler (so you can actually fill it), single outlet and this one usefully has a couple of internal baffle plates. There is a sender cut out which is not drilled at present. Dimensions: Width - 818mm Depth (front to back) - 211mm Height (tapered) - 159-188mm Sender cutout - 60mm Filler neck (external) - 52mm Needs a good clean on the outside but the inside is clean and the whole thing is sound with no significant damage. I'll fill it with water to check it doesn't leak. Reduced to £70. Collection from just outside Bicester.
Jitterbug Posted August 25, 2017 Posted August 25, 2017 Hi, I might be interested in this tank. Is it a westfield one or a fabricated one? I need to double check the measurements of mine which I will do over the weekend. Regards Mike
Michael Whitworth Posted August 25, 2017 Posted August 25, 2017 Might be interested in 2nd dibs on this if Mike doesn't want it. regards, Mike.
Geoff101 Posted August 25, 2017 Author Posted August 25, 2017 I have no idea who made it I'm afraid but it is one of the better quality constructed ones that I have seen.
Geoff101 Posted August 28, 2017 Author Posted August 28, 2017 On 25/08/2017 at 12:58, Michael Whitworth said: Might be interested in 2nd dibs on this if Mike doesn't want it. regards, Mike. Hi Mike, Jitterbug has passed on this so it's available if you would like it. Geoff
Michael Whitworth Posted August 29, 2017 Posted August 29, 2017 OK I will take some measurements and let you know.
Geoff101 Posted September 12, 2017 Author Posted September 12, 2017 Bump - offers welcome for collection.
Geoff101 Posted February 4, 2018 Author Posted February 4, 2018 Reduced again - £70. Please get this out of my garage!
Geoff101 Posted June 10, 2018 Author Posted June 10, 2018 Yes but I was waiting for someone to come back to me after they had measured up. I'll chase it up.
