Gi0tjv Posted August 17, 2017 Posted August 17, 2017 (edited) I have recently removed the reverse box along with the two prop shafts etc. Having a bike powered kitcar before without reverse I have had no bother in the past and feel that this is only adding unwanted weight to the car. It works perfectly well and will certainly be useful for someone building a bike engined car. My car is a factory built megablade. The propshalts both have a slider at one end. Front prop is 400mm closed and 430mm open, Rear prop is 790mm closed and 830mm open. Reverse box is 205mm long. £430 Inc postage to the UK. Edited August 24, 2017 by Gi0tjv Now sold
Terry Everall Posted August 17, 2017 Posted August 17, 2017 Have you seen the post in the Parts Wanted Section?
Gi0tjv Posted August 17, 2017 Author Posted August 17, 2017 New to this, thanks I just had a look and texted the guy. Cheers
Ragaman Posted August 17, 2017 Posted August 17, 2017 Hi Gi0tjv If the box and shafts are not sold could u please put my name on them as I`m about to remove a xflow from my Westfield and replace it with 929 blade engine. I also live in NI (Limavady) and could collect it from u. Could u send ur phone number. Regards Raymond
