DASH 2 Question
Hi Folks,
I have a DASH 2 fitted to my car, however the previous owner had never used any of the 4 configurable push buttons.  I appreciate they can be configured in any way, however is there a default configuration that is commonly used?  Failing that, is there a way of determining how they have been set-up with connecting a laptop?  i don't want to go merrily pressing away and reconfigure the settings as at present everything seems to work as it should!  I have had a look at the manual but that really only states that that the buttons can be configured as desired.
In the first instance it would be useful to know how to reset the trip.....!
Bob
Hi Bob,
On the earlier firmware you can configure the buttons with the buttons and no need for a laptop. See attached guide.
You have to enable the trip reset on a menu. See P18. I've got my left button set to Menu. Right to Trip reset and then up and down to scroll through the screens.
westfield-dash-instruction-manual-v32.pdf
@IanK Thanks for the info and the manual - i'll have a fiddle!
