Westfield boot box - Westfield racing green
I'm never going to use it...it's never been on the road, but was fitted briefly by the previous builder so has a few holes drilled in it and the holes for the Westfield standard roll bar....It's for an SEiW...£75....would prefer pick up for obvious reasons.
Is this to fit over a long range tank ?  If so where abouts are you ?
That's a good question..is there an easy way to tell.....
I'm about 10 mins from the Winchester junction on the M3 - Eastleigh.
It looks like a long range box in the photo. The long range tank is much taller than normal, so the boot box that goes with it has a huge step across the back, to cover the taller tank.
Looks like a long range boot box to me, same as mine.
It's the fuel tank that's long range, the boot box will only take you 50miles ;-)
Aye, the irony of it, the tank will take you even further, but the boot box holds half as much.
So, yep...to confirm, fits over the long range tank.
