Front Number Plate Mounts
Morning all,
I know this topic has been discussed at length previously, so i'll try and avoid the usual subject matter.  On a recent trip to Toybox, I noticed they were now mounting front number plates using flexible mounts, allowing them to hinge rearward in the event of being struck.  Unfortunately i didn't get chance to have a proper look at the mounts in question.  Does anyone know what they are using and where to purchase them from?  Alternatively, does anyone have a Toybox prepared car with said mounts that could snap a photo and post here.
Bob
I've done something similar using 2 cable ties. I pass one cable tie through the number plate and then through the hole in the body work. The locking bit prevents it pulling all the way through. I then used the locking bit off another cable tie to secure the first one. Cost about 2p for all 4 ties.
Mark
Don't think there is a an off the shelf solution,  most of us have our own ideas on how to mount them.    Motor bike well nuts are a neat solution.
I used a pair of small brass hinges.
Just be very careful if using hinges, that it doesn't appear to be a mechanism for folding the plate out of site to avoid something other than road debris ;)
If you happened to drive past a copper having a really bad day, at speed, with one pushed back flush to the nose by air pressure, you might suddenly be the one having a real bad day!
Thanks for all the suggestion, i feel a little research coming on (read that as trial and error!).
Bob
