mikey p Posted July 24, 2017 Posted July 24, 2017 Westfield re-packable exhaust. 6" diameter 24" long and includes link pipe (welded on) as they used to be supplied. Comes with the mount as pictured. The brace support has also been tacked in place as this used to rattle. It was also filled with free Acouta-fil around 2000miles ago. I measured this @ 93dB at 5250 RPM static. It was also around 85-88db driveby measured at 20m. 2" link pipe with 2" exit. The link pipe has a flared end to accept a 2" collector pipe. This is around 14"long and ~15Deg angle. I have cut the rolled end insert off as I think it looks better and it sounds better without it. I ran this with a 200BHP Duratec. It would only suit a drive side exit exhaust as its scratched on the bottom and a small dent. As all? of the re-packable exhausts seem to do it does still buzz at certain engine speeds. I also have for sale the 4-1 collector I used. This was off a caterham. Has a 2" exit and accepts 1 3/4" OD primaries. This is a proper merge collector with two lambda bungs welded in. This was cut and shut to make it on a 15Deg angle to match the link pipe. I have some pictures of it fitted if you need them, any questions ask. Silencer £125 collector £25 Both for £135 They are located in MK46. But could post at additional cost. PaisleyFreight do exhausts for £21.99 I think its this one but looks a bit different to the picture - http://parts-shop.westfield-sportscars.co.uk/index.php?route=product/product&product_id=169&search=exhaust&page=2
mikey p Posted July 26, 2017 Author Posted July 26, 2017 Silencer sold subject to payment. Collector still available.
bquansah Posted July 30, 2017 Posted July 30, 2017 Interested in collector if it's still available please? Could you post? pm sent!
