Hi Bunje
Yes Class F I understand is the correct Speed Series class but this class allows cars configured to either Road Going or Modified standards
We may have to double check the MSA Licence you need depending on which way you decide to configure your car!
Please advise how you intend to set up your car based on the questions I posed in my initial post!
It is best to get the correct info from the get go to avoid issues or delays later!
G
The cars i class F need to be in a road legal condition capable of passing MOT etc. However they can run on 1A,1B or 1C tyres. On the day classes would mean that if you run 1C tyres you will need to tun in Modified specialist production cars where other competitors will be running slicks. You need to have an MOT , Insurance and tax if you run in a Road Going class on 1A or 1B tyres. If you run 1C tyres and run in the mod prod class you do not have to bother with MOT , insurance or road tax as long as you get a Vehicle Passport for the car
Ah makes more sense now. I intend to run the car in its Road legal form. On road tyres. Will more than likely be r888r gg compound
Hi Bunje
If you are running under Road Going Regs in our Class F the Non Race National B MSA Licence should be OK!
I have been advised that if you were running under Modified Regs with your turbo taking you over 2000cc it MAYBE you would have needed to have a National A Licence!
If you would like to text me your address to 07887 554361 I am happy to send you my disc of the 2017 MSA Blue Book Regs if it helps?
It will give you some idea of the framework of the Regs to run motorsport in the UK but they are very wordy and somewhat difficult to understand in some areas!
Look forward to meeting up with you!
Graham (Glutey)
Hi graham
thanks for the offer on the regs are they the same as the blue book on the msa website that i have downloaded and printed off.
i wil most certanly run it in the wscc roadgoing Class F if thats where it would be put in the road legal form as id like to experience the whole sprinting scenario befor emaking any changes to the car if needed
Yes it should be so you don't need my disc!
Good luck with the reading matter you have down loaded and printed out
BR
G
Bunje
Don't worry about being in F as a new competitor.  I am a novice but run in F as I have a sequential box.  F used to be an expert class but this year there were novice target times in F so you aren't really at any disadvantage.
Most important is to get out, learn the ropes and see if you like it.
David
Yeh I had seen that David as I've been looking at the target times over the season. I'm hoping to get involved and juts enjoy competing.
21 hours ago, graham frankland said:
Hi Bunje
Graham (Glutey)
This is not correct. You do not need a national A for any production catagory, only for Sports Libre and Racing car catagories if over 2000cc.
Hi phelpsa
I did say "maybe" as I had been advised to check with the MSA about the need for the Class A Licence but it went away as Bunje is intending to run in Road Going!
G
  • 7 months later...
Got my timing strut made today.
also fitted a 1 litre catch tank.
Apart from a “tow” sticker on the cage I reckon the car is nearly ready.
Pity I can’t actually make any meetings before Blyton in May though :(
If you have not got a "TOW " sticker just put yellow tape on the cage tow attachment points you want to use
I can make stickers easy enough, the wife has a vinyl cutter, so race numbers are on the cards too :d
Nice job there Chris.
Ta. The fixings are the rubber captive rivnut things so that it can be easily removed for road use. Placed them on the lower edges so you can’t really see anything when removed.
