LED Indicators
I don't recall any specific led considerations anyware other than headlights. Obviously though, that's assuming they meet all the normal requirements etc.
The only thing, generally, you have to watch with LEDs is using the correct relative brightness compared to the other lamps - this tends to be less of a problem if using LED fittings designed for the specific role, ie indicators, brake lights, tail lights etc, but do watch out for it!
can't comment on IVA aspects but when I swapped over to LED indicators I searched for white items that flashed amber, as I was looking to use clear lenses and wanted to avoid the classic "fried egg" look.
Had to swap my flasher relay too to an LED compatible one.
What's your plan post IVA? Do you wish to stay Amber of go clear?
I IVA'd with LED indicator bulbs front and rear with Amber lens on the front, which are now clear.
My car may have some prominent orange accents anyway so I don't object too much to the amber lenses, although clear all around is a great look (especially matching up reverse and rear fog).
Position-wise, I've been thinking about two small 3D-printed casings to mount them on the outboard side of the headlamps (4" dominators), provided I can meet the angles and have sufficient clearance to the cycle wing (including lock-to-lock and in bump).
I'd stupidly forgotten you'd tango'd your calipers!
It won't stop there!
I have fitted these but the clear version. They are good quality,nice and bright easily equivalent to a 21w bulb and 'E' marked. I can't see why they would have a problem at IVA and I hope not as all my rear lights are LED. My IVA is soon so I will let you know. John
All my lights bar dip/main beam were LED for IVA, never even raised a comment.
Thanks all. What diameter are the standard indicators? 73mm sounds large (next to a 4" headlamp)...
@Monty My bog standard Westfield supplied ones are 70mm dia over the rubber boot ~ 68mm Orange lens.
