Andy (Sycho) Posted June 24, 2017 Posted June 24, 2017 13" Compomotive wheels wanted PCD 4x108 Ideally 2@ 8" Et 10 ish & 2@ 7" Et 35/40 ish long shot I know, but what have you got?
Rednop1 Posted June 24, 2017 Posted June 24, 2017 Andrew what brakes you running fronts may struggle to clear hi spec big brake kit
Andy (Sycho) Posted June 24, 2017 Author Posted June 24, 2017 Should be ok Ash only running ultra lights.
Andy (Sycho) Posted July 8, 2017 Author Posted July 8, 2017 Rears now sorted, just the fronts needed now! 2@13"x7" et35/40ish PCD 4x108
Andy (Sycho) Posted September 14, 2017 Author Posted September 14, 2017 Still need some fronts 13"x7" et40ish
GaryR1983 Posted November 10, 2017 Posted November 10, 2017 are you after the CXR or CXR2? I have 4 sets of CXR2 and a set of CXR but I'll need to confirm offsets later on
Andy (Sycho) Posted November 10, 2017 Author Posted November 10, 2017 Don't know, what's the difference? If they are not that much different I wouldn't have thought it mattered. Cheers
GaryR1983 Posted November 10, 2017 Posted November 10, 2017 the black wheel is a CXR2 and the silver is a CXR. The difference is mainly the detail around the lip where it meets the tyre.
John Loudon - Sponsorship Liaison Posted November 10, 2017 Posted November 10, 2017 2 hours ago, GaryR1983 said: the black wheel is a CXR2 and the silver is a CXR. The difference is mainly the detail around the lip where it meets the tyre. I think the other way around. I have a pair of 13 x 7 ET24 if of any use
Andy (Sycho) Posted November 10, 2017 Author Posted November 10, 2017 Yes the the black ones are the same as the crx's I have. 4 hours ago, John said: I think the other way around. I have a pair of 13 x 7 ET24 if of any use Thanks I keep that in mind but ideally I need a bigger offset.
