2.4 Quick Rack
You don't need heavy duty on our light cars!
On 03/06/2017 at 22:05, CrisisWolf said:
Heavy duty? Whats the differende between that and he 2.4 rally design 'typical' one as per: http://www.rallydesign.co.uk/product_info.php?products_id=7310
As per Rally Design website.
The strongest steering racks ever manufactured for the RWD escort.
  • Largest Diameter Rack Shaft 25mm Ø
  • Largest Diameter Tie Rods 14mm Ø
  • Preload Pad in Sintered Steel
  • Phosphor Bronze Pinion Support Bush
  • Heavy Duty Steel Centre Support Tube
  • 133mm Total Stroke Length
On ‎03‎/‎06‎/‎2017 at 22:16, Chris King - Webmaster and Joint North East AO said:
You do if you don't want to replace it after the slightest knock!
Just out of interest the bolt holding the column to the rack splines should have a plain shank at the top and not be completely threaded. This is to stop the threads wearing against the groove in the splines
