MWMSport Posted May 23, 2017 Posted May 23, 2017 Omex 600 ECU with Loom, temp sensor and airtemp sensor. Good working order, loom will require some minor work to bring back up to scratch, (relays need new terminals, coil plug missing etc, roughtly £15 in connectors and 30mins work) £sold 1.6 sigma engine with Piper Ultimate road cams. Blanks not regrinds (£475.20 on the piper website.) I brought this as part of a package deal but is not required as I'm using a puma engine instead. I have never heard the engine run, but was promised by owner it was good. I have carried out a compression test to be sure which was all ok. As I personally haven't seen the engine run, I can't garentee it's condition, so am sell as cams in a free engine. Engine is a bit grubby as it has a rocker cover leak. Gearbox not included. £sold Ford Focus ST170 engine. Complete with exhaust manifold, inlet manifold, injectors, coil, spark plug cover etc. I drove the car before removal. I brought the car for the brakes for my fiesta zetec s track car. Engine has loads of history to go with it including a receipt for a cambelt change at a Ford main dealer. Engine is as removed from the car, but I will throw in a slivertop sump conversion consisting of sump, windage tray, pick up pipe and longer mains bolts to mount windage tray so it can easily be mounted to a RWD gearbox. £225.00 All items located in Staines-upon-Thames- J13 M25 Can post the Omex but engines collection only please. 07985266042
MWMSport Posted June 9, 2017 Author Posted June 9, 2017 Omex and sigma engine sold. ST170 engine reduced to £225.00
