I'm putting together a small tool kit for my forthcoming trip to le Mans in the Westy .
I'm thinking clutch &  throttle  cable, Fuses , jubilee clips, insulation tape .
As for tools if I'm Not careful I'll end up needing to take a trailer  full for the just in case tools .
I need it keep it to a minimum as I've got to get camping gear in as well so any tips grateful excepted
Tie wraps, both metal and plastic type.
Gaffa/duct tape.
Mole grips.
Cheers Chris never cable ties never crossed my mind
Some electric cable to bridge broken or damaged bits
also worth having some spare fuses and a roll of tape
I already have a kit for driving in France with bulbs And And Fuses in  there already ( and a first aid kit ) important tool's are my main concern
Jubilee clips, selfamagamatinh coolant hose tape, Fuses, cable ties, duct tape,  mechanics gloves and a credit card.
Breakdown cover, credit card.
Here is our list for Euro trips:
Items
Allen Keys/metric/imperial
Assorted M6,8,10 nuts and bolts
Brolley (if you want)
Cable Ties (assorted)
Fire Extinguisher
First Aid Kit
Fuses large/small
Gaffa Tape
Hand wet wipes
Insulation tape
Jubilee clips assorted sizes
Jump Leads
Knife
Latex Gloves
Pliers
Pressure Gauge
Rags
Scissor Jack
Screwdrivers flat
Screwdrivers pozi type
Spanners normal
Spanners ratchet
Spare Bulbs (and any specific to your car)
Spare fan belt
Spare Throttle Cable/clutch cable?
Tow Rope
Torch
Tyre Inflator
Tyre pressure gauge
Tyre puncture repair foam
Warning Triangle (2 number?)
WD40
Wire cutters
Passport (each)
E111 health card
Insurance cover (European travel)
Breathalysers (2off) check dates on any old ones you have
Hi Vis vests (each)
Driving license (both parts?)
Car Insurance Doc includes for European travel
Car breakdown cover (repatriation)
V5 document
Printouts of Ferry tickets and list of accommodation.
Money (for beer/wine) let your bank know you may use your bank cards abroad
  • Like 7
Items
Fire Extinguisher
First Aid Kit
Fuses large/small
Gaffa Tape
Hand wet wipes
Insulation tape
Jump Leads
Knife
Latex Gloves
Pliers
Pressure Gauge
Rags
Scissor Jack
Screwdrivers flat
Spanners normal
Spanners ratchet
Spare fan belt
Tow Rope
Torch
Tyre Inflator
Tyre pressure gauge
WD40
Wire cutters
Passport (each)
E111 health card
Hi Vis vests (each)
V5 document
Brilliant! Spot on ....
I'd add a multimeter for tracing small wiring faults and some crimp connectors
Items
Fire Extinguisher
First Aid Kit
Fuses large/small
Gaffa Tape
Hand wet wipes
Insulation tape
Jump Leads
Knife
Latex Gloves
Pliers
Pressure Gauge
Rags
Scissor Jack
Screwdrivers flat
Spanners normal
Spanners ratchet
Spare fan belt
Tow Rope
Torch
Tyre Inflator
Tyre pressure gauge
WD40
Wire cutters
Passport (each)
E111 health card
Hi Vis vests (each)
V5 document
Excellent just the sort of thing I was after:yes: thanks
  • 1 month later...
That was a really handy list Marcus, with the addition of a few bits and bobs, like silicon self amalgamating tape for hose repair, some spare nose cone grommets, (I seem to have developed a habit of loosing them :blush: ) and spare exhaust bobbins, I actually had two spares, but then there were three of us! It's pretty much what we took.
In addition, we were all on 15" wheels, so the space saver spare I carry on the back of mine, would have fitted any of our cars for temporary mobility.
Dont forget those locking wheelnut adaptors if you need them too!
Also on the list should be metal putty which saved a boghouse brake fluid leak on a mad dash to the ferry terminal, I also carry a spare zetec thermostat housing as that easily gets cracked on a standard zetec if you bottom out on / off ferries etc
When we put the Euro trip tool list together I thought we were going to build a spare car with all those tools never mind driving somewhere.
Take note: The tools list was split between the 4 or 6 cars on the trip.
