Front indicator pod
Hi I need a front indicator pod. I bought pair ( eBay) ages ago and and now I come to use one the PO cut the mounting bolt off with a hack saw so I can't put a nut on there is no space or thread.
Long story short I need one pod or a different plan. It will need to be IVAd.
Hi Chris. Can you not drill out the remaining thread and retap the hole? Then fix in place with a bolt to fit the threaded hole.
I'm going to have to do that by the look of it. It's just a bit of a faf.
  • 2 weeks later...
Hi Chris
Did you manage to fix or replace your pod. If not and you still have it lying around I'm need one to test fit some leds so just after any old pod rather than cut up my existing.
Phil
Sorry put on the back burner. I need to get back to it. If I muller it completely I'll give you a shout :yes:
Ok :yes:
