Lightweight Zetec Flywheel
What I have is a late CVH EFI flywheel. They are just over 6 kg and have marks for crank sensor.
Bolt pattern is the same as 1800/2000 zetec all you need to do is drill out to 11mm. You can use a 1.6/1.8 early mondeo clutch that will have the same splines as a type 9 Or have it drilled to take a pinto clutch.
Ring gear is the same so re use starter.
A number of people on here have used them as have a number of other cars which use the zetec engine so they are getting rare now (the EFI ones).
I'm looking for £75. I'm at Stoneleigh on Sunday.
I will post for free if anyone is interested?
  • 2 weeks later...
Bump, also on locost builders now I have hit the 10 post target.
  • 4 weeks later...
I have one, but must be of use to someone!
