Josh Lawson Posted April 19, 2017 Share Posted April 19, 2017 I have standard wheels with a 205,50,15 tyres on at present... can I just switch to 195, 60, 15 for the price and how much will it affect the car? Any advice would be much appreciated. Quote Link to comment Share on other sites More sharing options...
stephenh Posted April 19, 2017 Share Posted April 19, 2017 Well you'll increase the diameter of the wheel/tyre combination by 29mm., so increasing the ride height by 15mm. approx. That will increase the circumference of the tyre by 91mm., so if your speedometer was accurate before the change, it will marginally under-record afterwards, and your overall gearing will be marginally higher. The difference is just under 5%. Why not go for 195/50x15", or 195/55x15"? The former will reduce your ground clearance by just 5mm., and lower your overall gearing by just 1.7%, and the later would increase your ground clearance by 4.75mm, and increase your gearing by just 1.6%. Quote Link to comment Share on other sites More sharing options...
stephenh Posted April 19, 2017 Share Posted April 19, 2017 If you were wondering what change it would make to the road holding and feel, then it depends a bit on what you use the car for. For road use I doubt you would notice the difference, and actually the choice of make and model of tyre would make much more difference. If you want to change to a 195 width tyre for cost reasons, I'd have a look at what is available in 195/55x15" tyres, as they would be closest in rolling radius to what you have at present. Quote Link to comment Share on other sites More sharing options...
SootySport Posted April 19, 2017 Share Posted April 19, 2017 Be aware the the tyre will be closer to the wheel arches. May be more awkward to fit the front wheels but certainly do able. Quote Link to comment Share on other sites More sharing options...
Josh Lawson Posted April 19, 2017 Author Share Posted April 19, 2017 Thank you all for your thoughts, to summarise, 195/205 makes no real difference on the rim, but are ok?! the biggest difference is the profile, and 195/55/15 is probably the Best To go for. many thanks, Josh Quote Link to comment Share on other sites More sharing options...
Arm Posted April 19, 2017 Share Posted April 19, 2017 Why not 205 again ? If thats a no then 50 series 195's Quote Link to comment Share on other sites More sharing options...
