Ali bodies pre-lit rolling chassis project
1988 Ali bodied pre-lit Westfield rolling chassis comes with the following:
Rear axle, with extended trailing arms, and Mumford link (requires finishing)
Open diff, drum brakes, vandalised fuel tank!
Swept wings and nose in red grp, rear wings in grey primer
Chassis has been modified for long trailing arms, and has had a number of the lower tubes replaced prior to powder coating in grey. The chassis is in good order and has a fixed hoop and diagonal, with rear stays
Windscreen, sidescreens and hood are all included
Front standard track wishbones with cortina uprights (needs correct hubs)
Escort rack.
Floor mounted pedals and cylinders
Rolling on 4 spoke revolutions wheels powder coated white
The Ali panelling has been very poorly fitted and requires replacing, which will instantly transform the car into a desirable classic Westfield.
Engine mounts are on the chassis for a x flow.
The chassis is correctly registered and comes with a V5 on a Q plate.
Priced to sell at £2375 ovno.
Call Paul on 07973 504785, to arrange viewing (in Harrogate)
Rare b******* this with the alloy body!
  • 3 weeks later...
engine mounts for a cross flow - what more does anyone need to hear??
If I wasn't already building one!!
Just imagine it with a tuned 1700 Puma, Elite gearbox, Force racing rims with slicks and carbon nose and wings front and rear :cool:
or a bike engine :)
10 minutes ago, tkm_dave said:
or a bike engine :)
wash your mouth out!
And, you can always have two, I'm sure second one would be easier especially as no need for IVA
On 5 May 2017 at 15:43, tkm_dave said:
or a bike engine :)
Ignore Loudone Dave, it's ideal for BEC project.
It looks to be a bit of fun to get in and out of the garage.
Yep, some turning circle required there...
Really? Not in my ownership! So it's a good job it's sold.
