Beggers Posted April 14, 2017 Posted April 14, 2017 I have for sale a 1.8 Silvertop zetec with paper work from Ford confirming its a 1995 engine pre cut off date. This means no cat required for IVA I believe? It has the 2.0 / RS 1800 spec 130hp cams so in theory on well setup carbs is good for 150bhp? Unknown milage and was running/driving in car before I upgraded to a 2.0 zetec over winter. No flywheel included. Being completely honest it will run and drive but it really needs a set of piston rings/rebuild. I had a bit oil usage per 500 miles and about 15% leak down and145psi compression and it really needs to be 175psi plus for a zetec so time for overhaul if you want to do serious milage. Collection only Milton Keynes. NOW £60 Need the space. The sump and the cams are worth that as parts :-)
Beggers Posted May 2, 2017 Author Posted May 2, 2017 Need the space and no value to me so £60 collected buys it. Sump sells for that alone on a well known auction site.
