My new build kit is in a local garage and they are having a look at the suspension setup. They have asked if on the rear suspension arms, there is a starting position for the end rose joints (top and bottom) from which the camber should be adjusted? Either a dimension to the centre of the rose joint or a number of visible threads.
Any ideas?
Cheers,
Simon.
All chassis and wishbones will be slightly different, so IMO there's no start position, it's just iteration.
