Hi All,
My throttle cable has just snapped underneath the accelerator peddle  aarrrhhh...
I have a Duratec engine - do I go to ford For a replacement or a local car spares shop?
Regards Richard
Also is it relatively easy to replace????
Most of the Duratec cars are on throttle bodies, so if yours is, it won't be a Ford part.
Bicycle brake cables can often be modified to fit, but without knowing for sure what induction system your engine has, it's hard to be specific.
If it's Jenvey or Omex throttle bodies, both Jenvey and Omex do sell spare throttle cables, if you want something that will fit straight on.
Just had a quick flick back, you mentioned your car has Weber Throttle Bodies in another post. So worst case, you could probably get a cable from Weber.
Depending on what the cable-end at the TB end is like though, a bike type cable may fit. (You can do it with Omex, but I've never tried on Webers)
Thanks for the reply Dave you are correct it has Weber throttle bodies. I'll have a look on their site
Worth investigating why it may have snapped too. Is there a throttle stop and is it properly adjusted so that the pedal touches at full throttle opening? Does the attachment where it has broken allow the cable to rotate so that it isn't being flexed back and forth?
Jen
I don't think a bike cable is a good idea, it may not be of the same quality. Lots of people sell throttle cables. You need to take your cable off, which should be a simple job, look at what sort of end it has at the throttle body end. It may well just be a plain cable end, the ones which fit Weber carburetors are (or at least mine is) because Weber supply all there own throttle leaver assemblies for any given installation, and you just supply a plain cable. If that is so, then the critical thing will be to buy a replacement of decent quality, of the correct length.
At the pedal end, I'd bet that on a modern Westfield with floor mounted factory supplied pedal box, the end of the cable will be locked by a grub screw, which will need a small allen key to undo the broken bit of cable, in a trunion pin which is free to rotate in the throttle pedal.
Trying to do this from the cockpit is a nightmare, particularly if you are on the large size and/or past the first flush of youth. However the top of the pedal box (ie above where your feet are when driving the car, is usually very easy to remove. On my old car it was a black panel of (from memory) plastic. That will be most likely fixed by a few pop rivets which you can drill out, or if you are really lucky the builder will have thoughtfully fitted it using small bolts into rivnuts (like I have done on my new XI!) in which case it is even easier to remove. Either way, if you remove that panel then getting at the broken cable end to remove it, and fitting the new cable will be quite easy.
You're right. Many bike cables are of better quality. (It's just the nipples at the TB end that aren't necessarily right.)
I had to replace my ITB cable supplied by Omex with a bike cable due to quality issues with the Omex cable, I'm afraid. It was literally sawing through the brass cable adjusters whenever not perfectly centered.
I too was doubtful at first about the bike brake cables, but got so many recommendations on here from people that had used them I decided to give it a try and was really pleased with the results.
PS, last time I spoke to Omex about it last Autumn, I think they said they'd sourced a different cable supplier where this was less likely to happen.
Plenty of threads on people fitting brake cables from mountain bikes and finding they are smoother and just as strong and much better quality than car cables. I have used them for years now without death.
Push bike brake cables are safety critical in a way that throttle cables are not. I would expect the quality to be good.
Jen
Jen
Indeed, that's been my experience after being persuaded to try them.
I've had this link on my fleabay account since I bought my Duratec, and I'm sure it was for a good reason.  Just can't remember what it was now!
https://www.ebay.co.uk/itm/231870533925
would be interested to know what you end up with as I keep meaning to get a spare to chuck in the "boot"
  • 3 weeks later...
Andy,
Finally got my throttle cable replaced. Took it to my local custom garage who specialise in MG, he used  cable from an MG took out the metal cable and threaded it throw the outer coating. Reasonable easy he stated!!
Any way she's back on the road...
The pull pressure on a properly set up throttle pedal is quite low overall. Usually the reason they break is that when the throttle is fully open, the pedal has not hit the stop and people are still pushing it harder. The weak bit is usually the crimp which pulls out.
Misalignment is also a reason
The cure is to make sure the pedal has a stop which is set at full throttle opening.
On 02/04/2017 at 07:19, snowy892 said:
Andy,
Thanks for letting me know, hope it works well!
As above,routing from the bulkhead to the pedal cable angles ,a pedal stop and making sure the cable end can rotate in the clevis/pedal are all the main issues with cables snapping :)
