Lightweight carbon fibre lowback seat for narrow Westfield
Lowback carbon fibre seat, 1.6 kg on the kitchen scales!
40cm wide at base, a few holes drilled where it has been mounted, will include 3 mounting bolts and plastic washers (lost the 4th!)
A few scratches from seat belts.
£620170217_115006.jpg20170217_115022.jpg20170217_115030.jpg£60 collected from Chelmsford, Essex or postage at cost.
Contact Derek 07885 874031
Do you have the mounts? Or was it bolted straight to the floor?
Barney these style of seat are normally side mounted to brackets with cup washers inside the seat
Similar to XTR2 says the seat was mounted to the rear bulkhead via the 2 holes in the backrest and to the side of the tunnel and the side panel via the holes you can see just ahead of the harness slots via plastic cup washers and countersunk allen headed bolts.
Thanks Derek, that's what I thought you'd say. Was thinking this would be a good passenger seat but I have a wide so won't mount the same way.
