:ww:
Have you seen the cars for sale section? I have something available now but it's in Herts:
7 minutes ago, Andy Banks - WSCC Shows and Events Coordinator said:
:ww:
I'm viewing a car on Wed morning, if its not the car for me this will definitely be next to see, comfortably under budget so would give scope for some upgrades
After a 200 mile round trip to sunny(!!!) Leicestershire today I can now say that I'm a soon to be Seight owner - I wasn't sure if an Seight would be the car for me, let alone a bored and stroked 5.1 litre Seight but the noise and quality of components made the purchase a no brainer - even if it meant I went over budget
Rubbish thread without any pictures or links to the car. Its the rules round here !! :d
:yes: when do you pick it up?
Beast of a car!!!
Here you go:
Westfield Wide body SEight Chassis built 2004
Weight approx 670 Kg
Aeroscreen
All aluminium panels are black powder coated
Crimson red Gel Coat (lightweight fibreglass body)
Nose can be removed in a couple of minutes.
Carbon fibre “Cycle Wings”
Removable Rear arches
Carbon fibre stone protectors
Carbon fibre “boot” panel
Carbon fibre dash
Westermann Motor sport Carbon Fibre half doors (forward tilting for ease of access)
Rose jointed “RAC” Roll Bar
5 ¾” black headlights
Carbon effect indicator pods
Rear carbon effect lights
Interior
Westfield Sports seats (fixed)
Willans 4” 4-point harnesses
Carbon fibre gear knob
Passenger foot rest
Instrumentation
Stack ST8130 Digidash Plus, with full parameter recording and lap timer
Displays:
Oil Temp
Oil Pressure
Water Temp
Fuel Pressure
Fuel tank contents (with low alarm)
Max Speed
Speed
RPM
Immobiliser
Engine
V8 5.1 l by V8 Developments
300 bhp @ 5200 rpm, 360 lbft torque @ 3000 rpm on 95 Ron
330 bhp @ 5300 rpm 380 lbft torque @ 3200 rpm on 99 Ron
Lightened flywheel
Vernier timing chain set
Dynamically balanced
Lubrication
3 stage John Eales Dry sump pump
Large capacity bespoke oil tank
Alloy catch tank
Aeroquip oil pipes
Fuel System
Bespoke extra long range tank baffled with integral swirl pot and foam filled
Fuel filler mounted on top of “boot” cover.
Jenvey Throttle bodies (8 off)
ITG Filters
ECU
DTA 8 PRO programmable ECU with Launch and Traction Control
Software and switch block/data cables
Cooling
Bespoke (Brise Fabrications) radiator
Electric (pull) fan and thermostat controlled by ECU
Samco Silcone hoses
Exhaust
Bespoke central underfloor stainless steel with 2 silencers to meet strictest track sound limits
Transmission
R380 gearbox
Heavy duty clutch
Ford Sierra 7” diff with ZF plated LSD 3.62 ratio, correctly set up and progressive
Steering/Suspension/Running Gear
Specifications for suspension were developed by head of Audi Chassis Dynamics (at the time).
Front and Rear Nitron dampers, Dyno’d and matched to springs
Front Anti- roll Bar
Oz Ultraleggera Wheels
Brand new Federal 595 rs 205/55/15 tyres
BG Quick disconnect steering boss
Quick rack 2.1 turns lock to lock (with stops)
Brakes
Hi Spec Ultralight 4 pot front Calipers with drilled discs
Sierra Rear Calipers with integral handbrake and drilled discs
Confused now ................. Ian to the thread. Explanation required !!
Simple explanation, Ian dropped me a line at the weekend, few emails exchanged re: the car, trip today to see it, deal struck to buy
I wish all the people I bought from made the process so simple and straightforward
Well its a hell of a car . Lets hope he gets a more road focused car, but well done for buying it. Just take it easy and enjoy !! :westy:
