Quinten Posted February 4, 2017 Posted February 4, 2017 At what point do you go for alu/metal pipe over silicon hose when you're plumbing your cooling system? Is it related to temperature (for instance, only on the hot side/before rad), or distance, or diameter? Quote
Thrustyjust Posted February 4, 2017 Posted February 4, 2017 Try and keep silicon hose as short as possible, within reason. Although others may disagree. You are more likely a leak from a flexible hose than a solid one. Quote
TAFKARM Posted February 4, 2017 Posted February 4, 2017 Agreed. Even more likely to leak from silicone / hard pipe joins. Quote
Quinten Posted February 4, 2017 Author Posted February 4, 2017 Ok, so limit amount of joins, and keep long straights in pipe? What about pipes with corners, can these be had 'over the counter'? Quote
