Feeling the pressure
For the first time in my engine swap I've tried to refit the nose cone and bonnet to see if it all fits...  Well, it doesn't.  Seems the fuel pressure regulator is the highest point.  Can I relocate this little wonder a bit lower?  Does the length of fuel hose feeding into it matter?  Does the height of the regulator matter?
You can put it where you want and change hose lengths
Brilliant, makes life a little easier.  Now just need to see if I can get a bit more clearance from the front of the engine as it looks like that is the next 'highest' point.
