Phormula Knock Analyser Pro kit
Possibly a little specialsed compared to the regular parts for sale, I admit. But vital for those seeking to remap their ecu's, to get the most out of tuned engines especially the turbo and supercharged guys.
An air fuel ratio meter will tell you how rich or lean your adjustments are making the engine run, BUT, in an noisy environment whether it's stationary on a dyno, or on the road doing your mapping, it's very hard to hear detonation and knock, until it's too late, making it tricky to fiddle with the ignition timing, by anything other than small amounts.
Thats where this kit comes in, f on one of the UK's leading specialists in such tools, this version allows you to actively "plug into" and listen for knock, live as you run an engine and adjust the  ignition timing and fuel settings.
The boxed kit, consists of:
  • The KS Pro high quality amplifier
  • Shielded interconnect cable for Knock sensor
  • Bosch Knock sensor - bolts to convenient spot on engine block
  • High quality, closed back Sennheiser headphones.
The web site of Phormula is here, with more details.
The kit has had very little use, the headphones show absolutely no signs of wear and the amplifier unit, (with orange rubber bumper in the shots above, is immaculate.
As you can see from the link above, these retail at £270 ex vat, £334 roughly with vat and carriage! Even on eBay, on the rare occasions these come up, they go for £190 +, typically.
Yours for £170 - protect your engine investment!
£150 and I will take it ;-)
I can pick it up for that if your map is correct? Sywell?
Damn, thought I'd fixed the map yesterday, sorry, no that's a hang up from trying to alter another areas monthly meet details. I'm up in Cheshire, Congleton in fact.
Did the 170 include the p and p then? :-)
For a WSCC member, yes I would include P&P!
(I'll be advertising on non WSCC sites over the weekend at £195 all in, otherwise...)
Yes please then! Pm you paypal/bank account and I will send the money.
Thanks Mikey, will pm you now.
