tuonokid58 Posted January 22, 2017 Posted January 22, 2017 I have for sale a fuel injection kit for a Ford Zetec E 1.8 engine in 130PS silvertop spec but can be modified by Webcon to suit all other Zetec E's for a nominal cost. The kit consists of a Webcon ECU with wiring harness and comms lead,instruction manual, fuel pump, fuel filter, air hose with filter and RS1800 Fiesta inlet manifold with throttle body, TPS, fuel rail injectors etc. I bought this to fit to my 1800i Westy thinking it would fit if I bought a V8 bonnet as it maximises power from the standard ford injection system to nearly 150bhp (from my cars 118bhp with the Ford EEC1V OGRE ECU) but I would have to cut a hole in the bonnet and I have decided to go down the 2ltr and Jenveys route instead. I'm advertising this on here as I know some members have other cars such as Escorts or other classics with Ford Zetec engines as this set up can be used in a Westy but a hole WILL have to be cut in the bonnet for the rear of the manifold to clear. Everything apart from the inlet manifold set up was for sale at Burtons for appx £1100 but I'll let the lot go for£750. Please PM if anyone interested Forgot to say when I got it I had it checked out at Webcon and they said it was ok as well as updating it to a later map then I never got around to fitting it. Also when fitted it does not need a rolling road set up. Here's a link for a Westy with the inlket fitted and how he modded the bonnet https://www.youtube.com/watch?v=xargAFhCKos
