DTA S60 Pro - SOLD!
As per the title. Perfect working order guaranteed. Now complete with new connectors pins and a lovely photo. These are £900 from DTA.
£550 plus shipping.
Bumped with edit.
I run mine on one of these! Great ecu for the money! Pop the spec up as people will be surprised what they get!
Also not on the list for some reason but supported by the S60 is TRACTION CONTROL.
Product features
Engine Configuration 20,000 rpm capability Flexible and easily adapted to different OEM, crank, cam sensor arrangements. Genuine four and two stroke support. Twin spark engines. Twin injector engines. Sequential or grouped injection. Individual coils, wasted spark or distributor. Unequal coil firing capability. Unequal injection angle capability. Delayed sequential injection. User controlled fan activation. Sensors can be calibrated individually with a lot of preset options supplied. Flexible Tacho Output Soft and hard rev limits Main Fuel and Ignition Functions Two main fuel, spark and turbo maps selected by a dashboard switch. Comprehensive start up fuelling options both time and temperature dependant. Air, coolant and manifold pressure compensation maps. Throttle transient increase compensation. Throttle transient reduction compensation. RPM and load breakpoints can be calibrated by the user. Throttle or MAP as load. All maps with one or two dimensional with interpolation as required. Lambda control functions Extensive lambda parameters table to ensure stable closed loop operation and emissions requirements can be met where needed. Full three dimensional lambda target map. Auto-tuning function. Turbo Control Functions Open or closed loop turbo pressure control via PWM valve. Modify target turbo pressure by gear selected. Modify target turbo pressure by vehicle speed. Two control maps selected by switch on dashboard. Active base PWM map for easy calibration. Idle Control Functions Open or closed loop idle speed control via PWM valve. Closed loop idle target speed temperature dependant. Active base PWM map for easy calibration. Fuel enrichment table calibrated versus PWM percentage. ALS Control Functions Full ALS ignition and fuel maps. ALS valve control together with map switching controlled by dash board switch. Cam Control Functions Open or closed loop cam advance control via PWM valve. Static offset table to zero out electrical movement effects. Active Cam Target Advance map, load and speed dependant. Active base PWM map for easy calibration. VTEC Control Water Injection When not being used to control the camshaft, cam base PWM map can be used instead for water injection, giving complete load and speed dependence. Flexible Input/Output Three uncommitted input tables which use 0 - 5 volt inputs or any input the S60 knows already, linked to fuel and advance modifiers and a PWM output. Launch Control Fully flexible first gear launch capability. Extensively tunable to individual vehicles. Full Throttle Gear Shift Cut Shift cut capability with 1ms resolution, variable for each gear with full switch de-bounce capability. Voltage Compensation Tables User configurable voltage compensation tables for injector dead time and coil on time (dwell time). Diagnostics and Test Features Full sensor diagnostics and fault recording. Extensive engine run time recording at different load and speed conditions. Ability to exercise injectors and coils without engine running for fault finding. Firmware The ECU firmware is flash upgradeable via the serial port with a special cable and software. Current firmware and software published on www.dtafast.co.uk. CAN PC Communications The ECU can communicate with the PC via our USB -> CAN converter. This solves the problem of unreliable USB -> RS232 converters. Data Logging Up to thirty six separate items can be logged. Three user selectable logging frequencies. Up to nine hours logging capability. Graphing can be done on-line to the ECU. Other Features Water Resistant Enclosure Sealed Latching Connectors Size 134 x 134 x 46 mm Weight 679 gm All outputs protected against over temperature and over current Inputs protected against severe wiring mistakes and accidents Reverse battery protection Alternator load dump protection Inputs and Outputs Inputs Crank Shaft (Magnetic and Hall Effect) 1 x Cam Shaft (Magnetic and Hall Effect) Throttle Position Coolant Temperature Air Temperature Manifold / Barometric Pressure Lambda Oil Pressure Fuel Pressur Oil Temperature Battery Volts 3 x User Defined Analogue (Shared Use) Launch Switch Shift Cut 1 x Wheel Speed ALS / Second Map Switch Outputs 4 x Coil Drivers 4 x Injector Drivers Tacho Fuel Pump Relay Fan Turbo Pressure Valve Turbo ALS Valve Cam Control Valve VTEC Valve Idle Valve Shift Light 6 x User Programmable Aux (Shared Use)
PM on it's way
Right, now I have to explain to the wife that I will be replacing my perfectly good MBE 967 ECU with a different one that will (in reality) make no difference to the car's performance or drivability whatsoever!
But I'm sure she'll understand that it is newer and has many more features to make it "future-proof" - and that by replacing an older component I have therefore made a justifiable upgrade decision on the grounds of reliability and safety!
It works for me anyway - just better not mention that "future proofing" in this case equates to enabling me to spend even more on upgrades!
A wise purchase
