Deanspoors Posted January 18, 2017 Posted January 18, 2017 Wanted as below for a gen 1. Rotrex C30/94 supercharger, and or mounting bracket Low compression pistons - 81mm 450/690cc injectors adjustable cam sprockets, with/without cams 12mm head studs Heavy duty output shaft Steel rods Bosch 044 fuel pump uprated clutch basket Blow off valve Billet plenum Cometic Head and Base Gasket Wide band lambda sensor Thanks, Dean
