Numbers Posted January 3, 2017 Posted January 3, 2017 1600 cc Vauxhall Engine, dry sump, fuel injected Engine rebuild prior to 2015/16 seasons. SBD supplied: Omega Pistons, Steel rods, Camshafts, Solid lifters, Peco Injectors, reprogrammed ECU. Track’N’Road March 2016, 169.9 bhp at 8,440, 121.7 lb/ft @ 6466rpm Gearbox is a Quaife clubman unit in a Ford box, paddle clutch and Quaife LSD. Foam filled custom fuel tank, MSA Roll bar, Sits on Avon ZZR's with a spare set of wheels with Toyo's Diff is a 4.1, a spare 3.9 crown wheel and pinion available Set up for sprints and hillclimbs, currently untaxed and without MOT but all road going equipment still fitted and working. Brand New FIA approved 4 point harness The car has a V5 and an MSA passport. £9,750 For more info call 07771977933
