Onliest Smeg David Posted December 6, 2016 Posted December 6, 2016 A few of us will be heading over to join up with Rickyboy's Yorkshire Dales Christmas Run... I will sort out a couple of pick up points from Manchester Area. tbc Hopefully weather will be favorable Quote
Rickyboy100 Posted December 6, 2016 Posted December 6, 2016 This should be a good run if the weather stays fine. Hope to see you all there Quote
Marcus Barlow - Show and Events Co-ordinator Posted December 6, 2016 Posted December 6, 2016 3 minutes ago, Rickyboy100 said: This should be a good run if the weather stays fine. Hope to see you all there I think you should make this an official ''silly hat'' run Rich Quote
Rickyboy100 Posted December 6, 2016 Posted December 6, 2016 You heard the man, let's do this. Optional atire for the day will be a silly hat. After all, were all gonna need a hat on. 1 Quote
Onliest Smeg David Posted December 13, 2016 Author Posted December 13, 2016 Reet then - Pick ups on route to Craven Heifer, Skipton.... 8:25 McDonalds/Shell Petrol Haslingden Bypass - BB5 2SB 8:50 Layby on A59 just West of McDonalds/Petrol on A59 between Whalley and Clitheroe - BB7 9WF 9:10 A59 through Gisburn - BB7 4ES 9:30 Craven Heifer, Skipton - BD23 6LA Quote
Onliest Smeg David Posted December 18, 2016 Author Posted December 18, 2016 What a Grand Day Out Gromit ! ! 19 'sevens' cruising around Dales from far and wide Thanks for sorting @Rickyboy100 , your route from Aysgarth to Muker was OK Started in thick heavy wet fog which cleared North of Grassington. Loads of crud on road. Adam & Myself (with Jonathan in tow) peeled off at Ribblehead for some sprightly X-rated Westie fun to Settle via Horton in Ribblesdale. We should do it all again in Summer? 1 Quote
