gee_fin Posted July 19, 2003 Posted July 19, 2003 Not my ad, but came across this through a RaceCar.com link. Might be of use to the Vx boys - http://www.xstyle.co.uk/41510.html Wade through the boy racer stuff and you find this "Throttle Bodies: SBD 208 2.0L XE Taper Throttle kit MBE 967E ECU, LM 967E - FWD Loom, Heavy Duty ARP Rod Bolt Set ITG Sausage Air Filter, 90mm Rams, with lazer cut backing plate Fuel pressure regulator, and lots of other smaller bits 4-1 big bore Exhaust Manifold - High Torque Cost £2,500. Still boxed and unused. Brand New! sell for £1,750 (with manifold)" Graeme.
