Beggers Posted November 17, 2016 Posted November 17, 2016 Converting from 1.8 Silvertop to 2.0 Blacktop over winter. After: A zetec short sump (I've got a 1.8 silver top sump from current engine but would like more clearance. Idler for water pump reverse. RHS engine mount (or worse case a pair of blacktop mounts). Alternator Bracket for Blacktop. I know seems a long shot but hoping someone has some of these laying around after upgrading to a Duratec or BEC etc.
Kingster Posted November 17, 2016 Posted November 17, 2016 My silvertop alternator bracket needed very little modification to fit the blacktop. Might be worth offering yours up 1
PeterL Posted November 23, 2016 Posted November 23, 2016 I bought a RH side engine mount from Westfield recently, £47 all in if I remember correctly. Its not listed on their site you need to call, they had it in stock
Beggers Posted November 25, 2016 Author Posted November 25, 2016 Thanks for the tip, will give it a go. Did you do silver to blacktop too?
Beggers Posted November 29, 2016 Author Posted November 29, 2016 Yep Westfield had a RH zetec mount in stock so that's a bit easier. Got the sump and alt bracket sorted so just an idler to reverse the pump direction now if anyone has anything kicking about please.
PeterL Posted December 1, 2016 Posted December 1, 2016 In the process of replacing a silver top with an ST170, which is effectively a blacktop. I may be treating myself to alternator kit which includes an idler. As I previously bought an idler I might have one going spare soon. Otherwise you can buy a pulley kit from race line. If in no rush drop me a pm and if I decide on the alternator kit I will let you know!
