Garage Clearout
Paul Hurdsfield - Joint Manchester AO
Std steering Rack, done 9,000 miles on my westy  £25.00
Std Nose Cone (non ducted) in need of some tlc,
yellow but needs tickling up and painting (trackday scars)
can be bolted straight on, I used it in this condition for almost a year.
off  a 1999 SEIW, mould ZK007, laminator GH, Production code 13DJ, pigment SB JC583. £25.00  SOLD
All the following off a brand new 1996 2.0ltr Zetec engine (mondeo)
Sump £10.00  SOLD
Water Pump £10.00
Inlet manifold complete with all injectors £20.00 SOLD
Exhaust Manifold £10.00 SOLD
1996 Citroen ZX, new genuine Citroen parts.
2 set of front brake pads £5.00 each SOLD
Handbrake cable £5.00
all parts ono
tel 0771 503 6769
WRT to the nose. Need to know what type of bodywork you have. does your dash go to the edge of the scuttle or do you have a rounded moulding on the edge of the scuttle ?
Thanks,
ACW.
Hyah Adrian
the dash goes to the edge of the scuttle,
if you check the mould number on your existing nose it should confirm whether the two will match, i can e mail some pics if you wish
Paul
Hi paul if the rack is still available I will have it
jeff
Rack is yours Jeff  :t-up:
you have pm
