markboyce Posted June 28, 2003 Posted June 28, 2003 META Cat 2 Immobliser M36 T2. Has been used in my westfield. Have since upgraded hence no use any more. Comes with whats-it you fix to the dashboard and then press key fob in to disable it. I didnt mark the wires up before removing it, but you have a 12 volt switched supply, ground and a constant 12v supply to the unit. There are then 3 circuits that can be isolated by the immobliser. Free to wants it, otherwise its going in the bin. Can be at Elvington on 5th July with Bookatrack. cheers mark Tel: 07740 706560 Tel: 020 8521 4230 (work)
