Black Luke 6 point harnesses *SOLD*
Out of date for FIA use,bit dirty and dusty but don't look to have seen much use.
Slight surface rust on some parts of the metal catches,will clean off ok.
My m8 bought these off EBay not realising they were for kit cars/single seaters so just after his money back.
I have had a offer for one on another forum,so if anybody wants a single one he is is willing to split.
£100 the pair posted to UK addresses,or £50 for one.
Do they work as 4 point if you don't plug the lower straps in?
3 inch wide?
I'll double check Russ but pretty sure they will work as a 4 point.
Shoulders are 3 inch,lap is 2 inch :)
I'll have the pair if they work as a 4 point.
I don't want to spoil any deals, but Russ, take a good look at your fixings, as the lap straps most likely won't be able to fit on the eyes it will require due to your seats spoiling
Not sure what you mean Q...?
These harnesses have fixings for eye-bolts. That's ok for the shoulder, but most likely not for the lap belts. Most likely you need
Takata-Bendable-Steel-Bolt-On-Bracket.JP
instead of
as you won't be able to screw in an eye bolt into the lower section because your seat is there.
He means you'll need to bolt the lap straps in rather than have them on an eye bolt.
You can convert 5/6 point to 4 point no problem :t-up:
THanks Q, I've already converted to eyelets and modified my seats so I'm ok!
In that case, ignore me :yes:
It's a good point though, it caught be out the first time round!
As above,they work fine as a 4 point :)
Sold pending payment cheers
Hi, Random suggestion, I am interested in 6 point, and have the same spec belts but in willans in black. i.e. 3inch shoulder 2 inch lap but they are 4 point. Would you rather these instead and i'll take the 6 points? Mine are currently fitted to car but easy to remove. Just a thought. No worries if not.
Tim
Sold thanks Russ
Tim
You'll have to drop Russ a message,as these are on there way to him now :)
