Lucas Rally optical distributor
Dizzy and power pack as sold from Burtons for £169 but excluding coil... (about 25 quid). Have seen it sparking but not working fully as decided to stick with my Aldon and points.
Hence £60 + P&P or I can take to Curborough
can you take it to curby so i can have a look at it ,thanks steve
What injun will this fit on to?
yours....
X-flow, complete with side entry cap to get under the webers
Hmmm..
And what difference would it make? And is it easy for a wally like me to fit?
Dead easy as I did it... (got it wrong) and did it again twice so I can advise...
As for advantages. It gives a better advance curve than normal distributor if you have a high profile Cam and of course once it's in you dont need to touch it again, no gapping points and replacing them after x number of miles
HTH
I'm supposed to replace the points?  :blush:
Er, once in a while yes
The service routine should be plugs, points oil and filters
