Chaps does anyone know if there's a way to increase the font size on the Boardroom on an Android phone? It's becoming just a little too small for when my old eyes are a bit tired. Changing the phone display settings doesn't do anything
When in chrome browser
Select three dots top right
Select settings
Select accesability
Slide until big enough
:yes:
Thanks Dave. Should have said Firefox. Accessibility option is there but changing text size still doesn't affect Boardroom
Firefox has a magnification change tool in the upper right corner, can't remember the icon, but it allows you to set the magnification rate for each individual website. It's a 100% and plus and minus signs. I have a 24" inch wide screen and have the forums set to 120%.
Thanks Scott but it's the setting on an Android phone I want to change not on my monitor
Swap browsers :)
Once I get fully into my new role I can look into this from the software side, but if Chrome does the trick, easy fix for now.
You can change text size on the latest Samsung phones by going in to settings then display , you can then select your font size . I think this will enlarge the font on Web based pages as well as and text msgs ect ect
Doesn't change the font on the Boardroom on my Motorola. Which is running Lollipop so should be no different to the Samsung. Guess I'll have to try Chrone
