Tillet seats
I've got a Westfield Megabusa which is a wide body and looking to fit some new tillet seats. What seat fits my car? Is it the b6?
Also, where is the best place to buy the seats?
Thank you for the link Sycho.
yes B6 are the seats to go for assuming that you are standard to slim build.
PM me or call 07768 022 712 if you want to discuss.
We have the B6 in stock in carbon and GRP with and without the edges.
regards
David
Hi David,
I tried PM'ing you however i think your mailbox is full,
Could you delete an old message and i will pm you again
Oops ..
I have had a clean up so should be OK again now
David
A big thumbs up from mefor the B6 seats. Amazingly comfortable. There not cheap but for me well worth the money
I have a wide bodied westy and fitted a B6 for me on drivers side and fitted the bigger B5 on passenger side. It just fits in so I can take bigger passengers :)
  • 6 years later...
Anyone know if the Tillet B6 Screamer XL fits ? or suggestions for the largest seat possible that fits ?
Unfortunately The XL will not fit in a wide bodied Westfield. I have had a customer try. The cars do vary depending upon chassis engine / gearbox configuration but generally a B5 is the widest that will fit the drivers side
regards
David
From a FAQ thread:
I want to change my seats, how wide is the cockpit?
Standard Wide Body, Sierra & Mazda SDV’s
Drivers Side - 16.75” / 425mm
Passenger Side (Wide Tunnel) - 16.25” / 410mm
Passenger Side (Narrow Tunnel) - 16.75” / 425mm
