Ianboom Posted October 11, 2016 Posted October 11, 2016 As in the title, I'm after the link pipe from the exhaust manifold to the silencer link pipe. Thanks Ian
darve Posted October 11, 2016 Posted October 11, 2016 Think I've got this in the garage new never used
Ianboom Posted October 12, 2016 Author Posted October 12, 2016 Hi How much do you want for it? Thanks Ian
darve Posted October 12, 2016 Posted October 12, 2016 Not much. Let me dig it out and see how much it will be to send
Ianboom Posted October 14, 2016 Author Posted October 14, 2016 Thanks, do you know if I need a mk1 exhaust manifold? I have a mk2 1.8?
darve Posted October 14, 2016 Posted October 14, 2016 I suspect they are the same. Someone more knowledgeable will be along to confirm
Mark (smokey mow) Posted October 14, 2016 Posted October 14, 2016 You'll need a Mk1manifold. The Mk2's are longer putting the flange for the link pipe in a different place.
Ianboom Posted October 14, 2016 Author Posted October 14, 2016 Thanks, I'll add that to the list as I want it running by Xmas! Is it worth getting the heat shield too?
Ianboom Posted October 15, 2016 Author Posted October 15, 2016 Does it need to be a mk1 1.6 or 1.8 manifold? Thanks Ian
Dommo Posted October 15, 2016 Posted October 15, 2016 1.8 if that's the engine you have. They should be common - I've got one you can have if you need it though you may well find one closer as the westfield manifold is a popular upgrade
Mark (smokey mow) Posted October 15, 2016 Posted October 15, 2016 ^^^^^ if yours is a 1.8 then you'll need a 1.8 manifold. The exhaust port spacing and bolt spacings are different between the 1.6 and 1.8.
