SOLD Westfield SEW 1800 Zetec 2001 £7500 SOLD
Selling this on behalf of a customer as he works abroad alot of the time
This is a very well sorted Westfield and I know that the current owner has spent in excess of what the asking price is, in the past two years.
The spec is below
Engine:
1800 Silvertop Zetec, this is a blue printed engine built for the 750 Motor club race series, by Stanwood Performance engines
Jenvey Throttle bodies
SBD Bosch injectors
Raceline Wet sump kit (just been fitted)
Dunnell Lighten flywheel
DTA EX48 ECU
Brand New bespoke motorsport Engine wiring loom
Omex Sequential Shift Lights
Westfield 4 branch Exhaust manifold with large repackable silencer (98db)
Westfield injection fuel tank
Aeroquip fuel lines
Sytec Fuel filter
Sytec Fuel pump
The engine has just undergone a service and has had oil, filter and timing belt
Transmission:
4 Speed straight cut Rocket Box with long first gear
RS2000 Alloy bell housing
AP Racing Clutch
Quaife ATB Limited slip diff which is 4.1 ratio
Brakes:
Front:
Wilwood Midilite 4 pot Calipers
Lightweight 260mm grooved and drilled discs
Wilwood Poly A pads
Rear:
Wilwood Midilite 4 pot calipers with handbrake
Wilwood Poly A pads
Suspension:
CAT Motorsport Widetrack
Protech rose Jointed dampers Front & Rear
Playskool Front ARB
Alloy Front hubs
Fully corner weighted and setup and we can do this for the new owner as well
Wheels:
Team dynamics Pro Race 1.2 rims
195/50 R15 R888R's
205/50 R15 R888R's
Tyres are like brand new and still even have the moulding dimples on!
Bodywork:
Canary Yellow Body
Westfield padded Sports Seats with yellow piping
Aerodynamics aeroscreen
Small Race Mirrors
Titan Harnesses
Carbon tunnel Panel and Interior panels
Lithium battery
PlaysKool Black Front wings
Ducted front nose
PlaysKool MSA Rollbar
Dominator Headlights
Carbon Mods dash
I've driven this car several times now and it's surprised me just how much low down torque it had and can pick its heels up and go incredibly well! Its a lovely car to drive and will make a good touring car, but will also happily do trackdays and sprints & Hillclimbs.
The current owner has probably only done 500 miles since we've upgraded the car from carbs to throttle bodies, so the likes of the fuel tank, fuel filter, fuel pump etc are all virtually brand new!
If you would like to know any more about the car or have any questions you can get hold of myself on 01388 762288 or luke@plays-kool.co.uk
Finally the current owner would like £7500, which considering the specification of this car I think it's a bargain!
14470538_10153927245847592_4193361987441
14433109_10153927246037592_7446221019154
14449856_10153927246152592_7874023784958
14522824_10153927245962592_3019173513277
14462713_10153927246197592_1364922611530
14495384_10153927245997592_6076954621038
14517387_10153927246097592_7905888081605
14517630_10153927245872592_6164131746149
Hi Luke,
Do you have a dyno sheet for the engine & the gearbox ratios - thanks.
Regards
Simon
Is this a fixed arched widebody?
Looks like it's a live axel with fixed arches
It is indeed a fixed arch widebody car with a live axle.
I'm just getting hold of the dyno sheet from the mapper. I don't have the gear ratios but will try and find out what they are.
  • 3 weeks later...
This is now sitting on my drive... Big grins tonight :d Thanks for all your help Luke!
  • Like 4
Adam  How is your self build progressing?  No blog updates for a while ....
It's not at the moment... Hopefully over winter!
excellent - what's the plan then?
Sort the driving position out then enjoy it :t-up: Seems that this is one of those 'much better than it looks on the spec sheet' kinda cars... See you at some track days no doubt. Also plan to do a bit in Class A Speed Series next year.
Excellent  :yes:
Great addition to the CLEAR Motorsport Team Yellow :)
Looks like we have a new team for next year's Speed Series then... ;)
Assuming I'll still be on board &, being the slowest by far, my contract is renewed :p
