Westfield heater -includes leg vents and ducting to demist but no windscreen fishtales. (It will need mini vents or something similar) Has plumbing that goes through the scuttle.
As new-used once in 3 yrs!!
£90 ono
Dave O.
Think I'll try again in the winter! I'll stick it in the loft with the other redundant westie bits!!
Dave O.
Before you stick it in the loft, have you got any pics?
I might be interested, but don't know anything about heaters so not sure what else I'd need to fit it. I don't have a hood so screen vents aren't required, just want something to keep the girlfriend's legs warm on cooler days.
Pinto Boy,
Sorry havn't any photo's of it :(
I think Hilux had a pic of one on his web site.
It's just the westfield standard supplied item with two leg vents and two screen vents. Three wires to connect it to your wiring loom. Two water pipes that go through the scuttle to the cooling system and the brackets to fit it to the scuttle :D
It's Vgc!!
Regards,
Dave O.
Dave, I could be interested.
What are windscreen fishtales and would I need them, could I get them?
Is it the westfield heater kit, inc:Heater matrix, plastic Tubing and ducting. Nuts Bolts washers etc.
Where are you based
Newboy,
The windscreen vents (fishtales) are still attached to my scuttle. The only reason I'm not including them is the pain in the  :arse: getting them off when a new pair would only cost a few quid.
I'm pretty sure vents from a mini or other BL car would do the trick (somebody correct me if I'm wrong!;)
Heater is vgc used once and is standard Wfield item with all fittings.
I'm in Herts.
Dave O.
Dave O,
Did you sell your heater?
Ian.
Still got it
Make me an offerrrrr :D  :D
Dave O.
DAVE O,
You have PM  ;)
