DannyScarbro Posted September 26, 2016 Posted September 26, 2016 Quaife ATB LSD in ford Sierra 7" casing with bolt on shafts, fitted with a 4.1 final drive. All in good working order and the casing is in great condition. Very hard to find these days. £895 Dan
John Loudon - Sponsorship Liaison Posted September 26, 2016 Posted September 26, 2016 Theres a guy on Uphill racers website after a 4.1 who also comes on here but not sure of his name on here (probably the same?) http://www.uphillracers.com/showthread.php?t=13300
Dave Eastwood (Gadgetman) - Club Chairman Posted September 26, 2016 Posted September 26, 2016 he's "thegunplumber" on the Boardroom, if you want to try pm'ing him...
DannyScarbro Posted September 26, 2016 Author Posted September 26, 2016 Thanks John/Dave, have sent him a text to see if he still needs one.
thegunplumber Posted September 26, 2016 Posted September 26, 2016 thanks guys I was told when one wheel lifts it will spin the power away rather than locking up like a plate LSD is this true.i understand they are good but possibly not so good for hill sprinting where tight corners cause the wheel to lift.any thoughts or exsperiances would be greatfully recieved
pete g Posted September 26, 2016 Posted September 26, 2016 i run quaife units no problem . no maintenance and no planet gears to break. plated diff if set up correctly is better . but dont discount the quaife unit ..after all new 4.1 crown wheel and pinion will set you back £680 and quaife unit about £750 . but you will need quaife output shafts to use . or get yours modified. you can always sell the quaife unit on. and swap with plated unit.if you dont like .
thegunplumber Posted September 26, 2016 Posted September 26, 2016 thanks pete think ill bite the bullet and give bara a call for a new one.i see you are doing curbourgh so will see you there.
