TAFKARM Posted September 22, 2016 Posted September 22, 2016 I've got my first MOT this afternoon using a new test centre since I've moved house. I've checked the lights all work, I'm on a Q plate so no emissions, no windscreen and only one seat so there can't be much to fail it on... Time will tell... Quote
Northwarks Posted September 22, 2016 Posted September 22, 2016 Good luck - always a worry but sails thru every time Quote
TAFKARM Posted September 22, 2016 Author Posted September 22, 2016 Passed! The usual shanter when any mechanic sees the car "I've got a 1.9 CVH that will destroy this" "What did you put a duratec in for" "I used to race but they banned because i was winning everything" I'll smile and nod if it means a pass! 1 Quote
Northwarks Posted September 22, 2016 Posted September 22, 2016 Passed! The usual shanter when any mechanic sees the car "I've got a 1.9 CVH that will destroy this" "What did you put a duratec in for" "I used to race but they banned because i was winning everything" I'll smile and nod if it means a pass! Thats so funny - I just grin and bare it for the 40minutes and get out, means to an end sadly. Had the same when I used to take my WRX there, how far can you drift it etc etc .... Quote
Martyn Vann - Warwickshire AO Posted September 22, 2016 Posted September 22, 2016 Congratulation Russ, glad it passed ok! 1 Quote
Man On The Clapham Omnibus Posted September 23, 2016 Posted September 23, 2016 The chap at my usual MoT place races a Triumph Spitfire so he's definitely got cojones of steel! Quote
dombanks Posted September 23, 2016 Posted September 23, 2016 Congratulation Russ, glad it passed ok! Indeed Quote
dombanks Posted September 23, 2016 Posted September 23, 2016 mine failed on cracked steering gaiters and a bit of "play" on the rear wheel which turned out to be a bolt that needed nipping up on the bush. NMS sorted the MOT so the garage issued the cert and they fixed the issues. ironically when they were fitting the new bushes I noticed the ball joint gaiter was also damaged so I guess its a new one of those at some point. all in all not bad and its legal again for a year. Quote
TAFKARM Posted September 23, 2016 Author Posted September 23, 2016 Good news Dom,nothing too serious! Quote
dombanks Posted September 23, 2016 Posted September 23, 2016 Good news all round by the sounds of it... just need to figure out why my speedo seems to be registering at 1/2 speed now! It certainly didn't feel like 45 mph Quote
