Onliest Smeg David Posted September 14, 2016 Posted September 14, 2016 This Jowett was outside MOT garage being worked on... ...certainly not the best example. It's a shame so much was so 'wrong'! Sure you knowledgeable lot will spot them? But at least it's being kept going on the road Quote
Man On The Clapham Omnibus Posted September 14, 2016 Posted September 14, 2016 Apart from the later style push-button on the floor nothing strikes me as 'wrong' in the sense of being out of period. There's a lot of restoration work needed though. Quote
Onliest Smeg David Posted September 14, 2016 Author Posted September 14, 2016 Apart from the later style push-button on the floor nothing strikes me as 'wrong' in the sense of being out of period. There's a lot of restoration work needed though.The push button is part of a modern lighting system being installed.Unfortunately it's not being restored. But there is another major wrong! Quote
Geoffrey Carter (Buttercup) Posted September 14, 2016 Posted September 14, 2016 Is it the running boards and that box thing. Quote
Onliest Smeg David Posted September 14, 2016 Author Posted September 14, 2016 Nice try, but Jowett had that running board and box. (Just Google imaged to check) Quote
Onliest Smeg David Posted September 14, 2016 Author Posted September 14, 2016 Is it the SU carb?On a modern (relative to car) Reliant engine.You can also see pipe to radiator only goes half height due to moder radiator fitment which is half size of original. Apparently it can go 60mph now! I wouldn't want to be in it doing that. 1 Quote
Onliest Smeg David Posted September 14, 2016 Author Posted September 14, 2016 An additional brake has been fitted, originally only having hand brake. A bike disk bolted inbetween gearbox drive shaft and prop!!!!! Quote
Man On The Clapham Omnibus Posted September 15, 2016 Posted September 15, 2016 I spotted the SU carburettor and didn't put two and two together regarding Mr Skinner's invention. Exactly when the leather bellows were replaced by a piston arrangement didn't enter my head! The top hose certainly is a giveaway but I didn't spot that either... Quote
Onliest Smeg David Posted September 15, 2016 Author Posted September 15, 2016 I spotted radiator then it was when I saw the word 'Reliant' on the head that I knew it wasn't original. But I deliberately didn't post a photo of that Quote
