Dave Eastwood (Gadgetman) Posted August 24, 2016 Posted August 24, 2016 Well there should be two to each normally, ignoring waste pipes. Plus a cold feed to the toilet Quote
Dave Eastwood (Gadgetman) Posted August 24, 2016 Posted August 24, 2016 Incidentally, did work on a site once where the toilet was accidentally plumbed into a hot water circuit! 1 Quote
John K Posted August 24, 2016 Author Posted August 24, 2016 Incidentally, did work on a site once where the toilet was accidentally plumbed into a hot water circuit! You have no idea how warm you are getting (and there is a clue there as well) And no I don't have the wrong feed going to the loo or either tap Quote
Deanspoors Posted August 24, 2016 Posted August 24, 2016 radiator pipes? or forgot to felt the chipboard? Or was it the shower head making the noise? Quote
pistonbroke Posted August 24, 2016 Posted August 24, 2016 You got Harold Steptoe to do the plumbing https://www.youtube.com/watch?v=kaTE1nvq9pU Quote
SootySport Posted August 24, 2016 Posted August 24, 2016 You connected the towel rail or rad to the domestic hot water supply. 1 Quote
Nick Algar - Competition Secretary Posted August 24, 2016 Posted August 24, 2016 I bought a new house where hot & cold water had been swapped at feed to tank end. Thankfully a reasonably easy fix!!! Quote
Dave Eastwood (Gadgetman) Posted August 24, 2016 Posted August 24, 2016 Hot tap connected to heating system? Or trapped the felt in a floor board, causing the board to rattle when the pipes near it moved. Quote
John K Posted August 24, 2016 Author Posted August 24, 2016 OK first things first to preemptively protect my reputation... I'm quite good at DIY and when I do a job, I do it well. So I sort of knew what was causing the knocking and knew what to look for and to make sure that all the copper pipes could move over the joists easily. So when I said I did a good job of putting the plumbing felt at all the rubbing points I did. Except... I did the cold water pipes not the hot... So when I was sat on the bog listening to the knocking I was wondering how the hell... Because I knew all the pipes were floating free. Yeah... The wrong pipes So last night I wrapped the right pipes and the noise stopped. Strange that eh..? 3 Quote
