Another dry event that will be scored as wet. Works in my favour this time but is there a mathematical way to stop these anomalies (maybe based on average times from previous events?)
It was also a shame to be separated out from the usual classes. Does the special Wscc class still work with numbers being down?
A good day as a spectator.
your runs looks committed through crossing ;-)
A shame about the Manic Beatie.  I hope it will be out again soon.
David
David
I scared myself a bit on T1, a bit close for comfort! It seemed a bit dirty there from people clipping the inside bank in the wet?
Managed to record identical times on the two runs which was annoying! Gained 2 tenths to bottom ess on the second run with more commitment through kennel but lost it all getting a wheel on the cement dust through the esses :( still a new PB with a 31.14 but annoying knowing that there is a 30.something in there.
Let me have results when you get them
Just to say I think that some of the ess approach speeds were a little dubious and the commentator was questioning them.  e.g. 158 for Trevor Willis !!
David
What happened to the Manic Beattie?
Didn't see the accident but when it came back down it was about 4ft shorter than when it left the line :(
Oops
Crashed at Kennel.  Rear appeared to clip the recticel and that then pivoted the front which dug heavily into the banking.
Mr Mann walked away unharmed
Can someone confirm Westfield Speed series entrants were
Charlotte Phelps
Adam Pheps
George Newrick
Craig Spooner
Mark Schlanker
Mike West
Adam
I do not think it is a wet event!
Adam
Correct, I was looking at the wrong time for Craig! Its close running though (50/50) and i guess my question still stands.
yes it is 50/50 (505) so a dry result for the 6 competitors
