from bottom up ,
full dry sump system,
farndon steel crank
farndon long rods
accralite slipper pistons
arp rod bolts
arp flywheel bolts
steel flywheel ,machined to trigger crank sensor
AP tripple plate clutch
alloy front pulleys
big valve head ,fulley ported
3 angle valves
bronze guides
double springs
titanium caps
lightweight solid lifters
SBD cams
kent verniers
swindon roller barrell throttle boddies with carbon trumpets ,DTA managment
etc etc
just run in and dyno run only
a conservative 270 + bhp @ flywheel with  more to come with a little more mapping
£ 5700 ono
well someone had to ask didn't they . ;)  9500 rpm  :0 and its grey with a silver head  :durr:  ;)
...and with the rod bolts above the pistons  :D  :D  :D
Seriously, sounds the dogs danglies - QED ask for well over £10 k for an engine with all these goodies.
JL
john that was just for you bottom's up  :(  :arse: ,is the mighty puma ready yet  ;) i bet palmers s***ting himself  ;)  :durr:  :blush:
Steve I am very interested.
No not just me day dreaming again :angry:
What is the history of the engine and bits?
Age etc.
Do you deliver?
Has he eaten a dodgy curry then Steve   :D  :D
mine was a serious question!
Been talked out of it.
The voices within win this time
All yours westy
not looking to buy just always interested in that spec of engine :blush:
