Zetec Dry sump system
Due to an upgrade I have my original Zetec dry sump system for sale. Includes sump pan, pump and connectors and crank pulley. The belt is broken, but is usefull to get the correct size. This is in working condition, but you will need a tank, remote filter housing and some plumbing to fit it to your car.
Price £250
Neil,
How much would you estimate the remaining parts would cost to finish the kit?
Tank £££?
Belt £££?
Filter housing £££?
Plumbing £££?
I'm obviously worried aboput ground clearance when I fit the new engine.
Nick
I got my tank 2nd hand for £40, belt will be about £5, remote filter mount about £15 + standard filter, plumbing about £100 max as long as you don't use alloy fittings! Bits from Think Automotive or (cheaper I think for the plumbing) Hydraquip
I'll give you call if I can still find the number.
Nick
  • 2 weeks later...
