SOLD - Westfield Mega S2000 Font & Rears Gaz shocks
As per title wide track front standard rears with springs 350 lb fronts 200 lb rears 1.9 inch. Brand new in 2015, done about 1400 miles
£250 + p&p
Will split springs and dampers if 2 takers
Bump
Get em now before I go on holiday for 2 weeks.
Don't know the answer about valve's. Maybe ask Mark at Westfields
These won't be compatible with a bike engined car? Would it be easy enough to tune them or would new valves be required? *I have a Megablade
Unless done as a one-off, or a recent addition to the factory range, I suspect they're standard Westfield spec Gaz's as used on any model. As far as I'm aware, it was Protech who came in and did a version of the dampers specific to the Mega S2000. Or at least that was the case a couple of years back when I was building mine.
That said, if anything, that makes them more compatible with a wider range of Westfield models, especially the lighter weight cars. Worth double checking with the factory though.
I might be interested in these! I'm running a SEW with widetrack and fitted with an ST170.
Based on Dave's comments above, I'd be interested in what the factory has to say first..
Potential buyers. If you want the shocks and springs you will have to let me know by end of play tonight. They need packing and sending by tomorrow morning. After that I'm away for 2 weeks.
  • 3 weeks later...
Bump
You have a PM.
PM replied
