2005 westfield seiw, vauxhall c20xe 250bhp
2005 westfield seiw, two previous owners, only 7000 chassis mileage, recently had a refreshed higher spec engine fitted making 248 bhp 187lbft with dyno, in excellent all round condition, well built car with lots of nice parts and upgrades, ideal road/track spec, lots spent in the last year on upgrades and maintenance. Always garaged and dry use only. Selling due to lack of use with family commitments. Spec is as follows-
Chassis- 2005 widebody, front and rear wide track, independent rear suspension, rac rollbar, quick rack, around 550kgs weight
Engine- vauxhall redtop c20xe, 248bhp 187lb ft, spec is- qed sump, steel oil pump gears, steel rods with arp bolts, omega forged pistons 12.9.1 compression, fully ported head, cams and verniers are bilas 296' duration and 11.5mm lift, double valve springs, solid lifters, bronze valve guides, simpson race exhaust, gsxr 1000 throttle bodies, port matched and flowed inlet manifold, omex 600 ecu, lightweight lithium battery, alloy radiator. Very driveable and smooth power delivery, can be driven slow or fast depending on your mood, i didnt want the car do only be able to be used flat out and a pain the rest of the time so its been built/specced/mapped with this in mind.
Transmission- getrag manta 5 speed box, sierra 7' lsd, 3.92 ratio, lightweight alloy fidanza flywheel, standard clutch so drives very nice.
Suspension- protech shocks all round, recently corner weighted, front anti roll bar.
Brakes- new westfield/hi spec 4 pot front callipers with drilled/grooved discs and new mintex 1144 pads, rear callipers are sierra 4x4, ap racing uprated master cylinder, dot 5 millers fluid
Wheels+tyres- compomotive cxr 13' wheels, lightweight nuts, yokohama a048 tyres all round.
Interior- westfield padded sport seats, luke 4 point harneses, minimal lightweight carpeting on the rear bulkhead and tunnel only, smiths dials/gauges, suede snap off steering wheel, shift light, immobiliser.
Im asking £11995 ono. You can call me on 07752503234 if you have any questions or would like to view. Thanks
BECB861B-0A03-4B52-A586-BFB344401A8F_zps
C1DAF198-A959-48C1-BF5A-6914B3038E2B_zps
F90E1988-AAEF-45C8-8E60-07D4FE277E32_zps
D306CCD7-AEDD-471C-9D5A-ABF06C53D560_zps
9DFBC317-2FC6-4D31-BB50-B910AA204DAC_zps
0186350A-08EF-413B-A617-EC6A73F46F44_zps
12CAE039-63BF-45C7-8961-C00DACDE15D5_zps
D433A7A5-0FEE-4F65-A772-38B229BB2462_zps
8A6D487C-DBA0-4993-BAD8-E6F01BDED98A_zps
DA9C6A20-48C8-4A65-92B6-B4ABAE30FC2E_zps
FAFB59FA-ADA8-4D8C-8030-FAD5F0BE6B37_zps
Beautiful car, good luck with the sale
  • 2 weeks later...
Reduced to £11495
  • 4 weeks later...
This is beautiful! Can I call when I get home from work at around 16:00?
